11-08-2022 03:47 PM
11-09-2022 05:49 AM
Paying by pre authorization gets you $2 off your bill every month.
11-08-2022 04:07 PM
You can pay your PM bill with voucher or with registered credit card on file.
Log in to your account and
or call 611 and with card or voucher.
You will be just adding funds to account and then on renewal day they will be taken from available funds. It is advisable to have funds available few days before renewal. Or to have set up autopay and register credit card and not to worry anymore.
11-08-2022 04:04 PM - edited 02-17-2023 08:37 AM
Hi @Glo_1 best way to do is to setup Pre-authorized payments
So, do you have a credit card on My account yet? Set up there, then you can either pay manually or setup auotpay
11-08-2022 03:50 PM
Bills? For paying this bill, you can use a registered credit card or vouchers or real time payments. You can login for the first two. You can use 611 for the second, You can use 611 and your 4 digit account pin for the first. The third is in some stores.
You can also use the chatbot.
