How do I get LTE working on my iPhone? All I can get is 3G.
03-02-2015 12:26 PM - edited 01-04-2022 12:34 PM
I can't seem to be able to get LTE working. Has anyone else with an iPhone been able to get LTE?
Thanks! 🙂
Phones
04-05-2015 12:19 AM
04-04-2015 11:18 AM
04-03-2015 03:32 PM
04-03-2015 03:01 PM
http://productioncommunity.publicmobile.ca/t5/Announcements/iPhone-Update/m-p/1610
04-03-2015 02:44 PM
04-03-2015 12:45 PM
04-03-2015 12:29 PM
04-03-2015 09:10 AM
Hello @justanormalguy,
Are you in a LTE zone where Telus offer LTE ?
How old is your SIM card? You may need a new one who is LTE compatible.
04-03-2015 08:47 AM
Me too
I came from Rogers , with Rogers for 12 years . Paying way too much
The only problem I have with PM is this : No LTE ..only 3G no matter how I tried. Definitly much slower than LTE with Rogers before ..but ,what the hell ...I m not going to pay 80 dollars a month. 🙂
Keep up public mobile Good work so far but please,fix the issues. Dont disappoint me and us .
03-04-2015 04:04 PM
03-04-2015 02:04 PM
Just 5 iPhones, and none of them worked.
03-04-2015 01:58 PM
Just curious @mackpine , have you put your sim cards into any other phones to see if you're able to get LTE?
03-04-2015 01:43 PM
In response to everyone's comments, I have an iPhone 6, 6+ and 5s... I've put the sim card in each of these phones (all unlocked), and LTE hasn't worked in any of them. I am in downtown Ottawa, where I know there is LTE. I've turned LTE on in the settings menu, and I've entered all the APN data... Still nothing.
03-03-2015 10:21 AM
@OP, if you have and iPhone 5 and up and don't have Data then you have no use for LTE.
03-02-2015 06:08 PM
What sometimes helps is to toggle Airplane mode off and on.
03-02-2015 05:57 PM
LTE settings are under cellular settings as someone previous mentioned
03-02-2015 12:42 PM
Check the post here for details: http://productioncommunity.publicmobile.ca/t5/Announcements/iPhone-Update/m-p/1610/highlight/true#M4...
03-02-2015 12:31 PM - edited 03-02-2015 12:31 PM
If your iPHONE is LTE compatible, Go to Settings, cellular turn on LTE
