06-30-2022 04:33 PM
06-30-2022 08:23 PM
If you were to guess .... can you try on 611?
06-30-2022 08:00 PM
When did you activate? You chose it at activation or if you activated at a store you chose it when you created your account. It has 4 digits. Did you use the same one as your old one from your old provider? To pick a new one you have to contact customer support.
06-30-2022 04:42 PM
@clevrkevr wrote:Please help me find my PIN...
Check on your phone device to see if you have a text messages from the day that you opened your account. In that text message, the PIN number will be in there.
06-30-2022 04:41 PM
@clevrkevr You might have received a PIN via email/text when you first activated your account. Otherwise you'll have to submit a ticket via chatbot and ask customer support to allow you to reset your PIN. Here's a link to chatbot: https://www.publicmobile.ca/en/on/get-help
