How do I even connect to a support agent?
NickVvvvvv
Hey,
Here is a problem:
I started a number transfer but my esim is not activating. When I try to sign in it sends me a code. To a number which I don't have now since my esim is not working and the number has been  already transferred from my old provider.
I am trying to connect to an agent, but it's annoying just ridiculous endless loop.
PLawl
I had this issue before and was able to get the 2FA code through email after entering the wrong code / requesting re-send of the code a couple times.  You could give this a try to get logged back in, then updating the EverSafe number on your profile.
NickVvvvvv
Thanks. I cannot make or receive calls.  I cannot received 2FA since I don't have a phone number now since it was transfered from old provided to public. So I cannot sign in to my account in any way.
@NickVvvvvv contact support to have them update the correct phone number to receive 2FA
and how about your activation and porting? can you makes calls or receive calls?
