How do I change my phone number
Merky99
I moved to another province and want to change my area code.
smp99
dna2016
@Merky99 Log into "My Account", select "Plan and Add-Ons", you'll see "Change Phone Number" as a sub menu to select from.
When changing your number you most liekly won;t be able to keep all the digits, they only give you the option to create your last 4 digits (this is standard throughout all cell companies).  So I highly doubt that only your area code will change, I'm sure just about your entire number will change.
AmosMartin
Log on to your account online. On this page on the right side you should see an option called: Change Number.  Clear instructions are given after this
bf7
Login into your account -> Plans and Addons -> Change phone number -> Select a new number. Make sure you select the "local calling area" you want to get the correct area code. You likely won't be able to keep the same number in the new area code as someone may have it already.
