How do I change my address?
BigDintheNorth
Hi, how do I change my address?  It says "invalid address" when I try to save my new address in the Account Info page on the website.
I know it doesn't affect billing, but I don't want my old address on file.
Thanks.
2 REPLIES 2
will13am
@BigDintheNorth , it has been a while since I had to make an address change in my accounts.  Unless there has been major changes, the system appears to use location services to assist with filling in the address.  I found using the mobile app with location permission on to be the most effective solution.
@BigDintheNorth
Check to see if the Postal Code is correct.
