10-21-2018 08:47 PM - edited 01-05-2022 02:14 AM
Hi,
I just want to reset my name in my voicemail. I don’t want a personal greeting.
10-22-2018 07:56 PM
It worked ! Thank you so much for your help !
10-22-2018 12:28 AM
Awesome
10-22-2018 12:00 AM
Awesome instructions
10-21-2018 11:56 PM
@sarah1320 wrote:I understand, but I don’t want to have a new greeting. I simply want to re-record my name, since I don’t like the way I said the first time. Is it possible to reset the voicemail so I could re-record my name ? I really want to use the assistant voicemail.
Try these steps
So it looks like if you dial your voice mail and go 4-4-3 that will get you to your recorded name and there is probably an option to change it
10-21-2018 11:45 PM
10-21-2018 08:50 PM - edited 10-21-2018 08:51 PM
Here is the link for the knowledge article on setting up your voice mail:
How to change your greeting
Dial into your voicemail. From the main menu, follow the arrows in the below visual.
