How can I port my old number from bell to my PM number?
zmh0312
I want to port my other bell number to my new PM account. How to do it. Thanks
2 REPLIES 2
NDesai
You can request to port in from your self-serve account under the Change Number option.
ShawnC13
If you set up your PM SIM with a new number you can still port your number over after the fact.  When you sign into your account and are on the overview tab, on the right side it will have My Profile.  Under that the last option is change my number.  Click that link and it will bring you to the page where it asks if you want a new number or to transfer an existing number.  When you are porting make sure you fill out the information correctly as it is on your Bell Bill.  Give them your Account number and use a number they can reach you at if there is an error and make sure you have checked the box that says you are authorized to transfer this number
