Transfer number
Tigger123
Seems that I have cancelled the SIM card before I received the text to confirm account. What should I do now
2 REPLIES 2
Neil11
You will need to contact customer service agent to fix your issue.  Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
@Tigger123  Are you trying to port number over ? Did you leave old providers sim in the phone to reply YES . Or did you cancel the old provider account before trying to port ?
