06-18-2024
01:50 PM
06-18-2024
03:27 PM
computergeek541
I'm currently overseas and unable to receive texts. Is there a way to log in without receiving texts?
I know my ID and password.
My Account
06-19-2024 03:14 PM
Thank you so much. I can log in !!!
06-18-2024 01:55 PM
hi @Wiseman1
yes, you can . On the login , at the security code page, just click Didn't receive code. Check if email is an option on the next screen, it should. Then you click on Send Email and you can then get the code via email
