02-03-2024 05:08 AM
Please I need my pin. How can I get this information
My Account
02-03-2024 07:43 AM - edited 02-03-2024 07:44 AM
You could ask the Customer support agents if they will confirm it for you, however the only self-serve option is to amend the PIN (it won't display for you)
Log into self-serve, then tap the Profile tab.
There, you'll see this:
From there, tap the PIN password area, then you'll see this:
Follow the prompts, reset the PIN, memorize it or keep it somewhere you can find it, and you're done.
02-03-2024 06:57 AM - edited 02-03-2024 06:59 AM
In your account profile page @Lere tap the pencil nest to PIN password and you can change it to what ever 4digit you want it to be
