How can I be able to send and receive pictures through text? I have looked through comments and vide
Why
Why can't I send or receive pictures through texts? I have done the apn but I'm missing the mms proxy I have mms proxy. I'm not sure what needs to be done or what else I have to do for it and it's a Samsung Galaxy 3 android
9 REPLIES 9
Cyber
@Why,
Glad to read that your issue has been fixed.
You can accept my first post as the solution and give me some kudos !
Why
It worked thank you very much
Cyber
@Why,
Please double verify that you entered correctly all the APN setting.
Try to reboot your mobile.
If it's not working, reset your APN to default, then configure it again.
Why
I have done that and I'm still getting the same message?
Cyber
@Why,
You need to activate your Mobile Data.
Why
I have done all that but it still says current unable to download. Please try again later is there anything else you can think off that might be wrong with the phone?
Cyber
@Why,
Choose "internet +mms+dun"
Why
In the apn type the only options I have are
internet +mms+dun
internet +mms
Internet +dun
internet
mms
dun
witch one do I choose?
Cyber
@Why,
You need to configure your APN settings to be able to send pictures (MMS) and navigate on internet (DATA)
Android APN step-by-step configuration :
Lithium-OrangeBullet-Jan23-00.jpgStep 1
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Click here for Android APN Screen Shot
Lithium-OrangeBullet-Jan23-00.jpgStep 2
You will need to input the following information :
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: default,supl,mms,dun
Lithium-OrangeBullet-Jan23-00.jpgStep 3
Select Save/Done. Select Public Mobile to connect to the Public Mobile network.
