08-24-2019 02:07 PM - edited 01-05-2022 06:37 AM
Hi everyone. I finally got my canon ip110 printer working on my phones hotspot. My question is will I have any issues when I’m in the us. It’s working with p/m when I print something. Will it still work when it switches to t-mobile or at&t and I need to print something ? Thanks
cheers
don.
Phones
09-01-2019 09:28 AM
Thank you it all worked out well
08-24-2019 03:36 PM
@Anonymous Thanks and let’s hope I don’t have to do anything. I’m am not handy in the technical dept.
08-24-2019 03:25 PM
Make sure the printer can get an ip address via DHCP from the hotspot. I would imagine served addresses could be different going to a different isp via the hotspot. But then maybe with the roaming where you don't have to change anything won't matter in that regard.
Maybe I have a crappy wifi printer but I had to set it to a fixed ip.
08-24-2019 03:11 PM
@geopublic Thank you.
08-24-2019 03:10 PM
Thank @computergeek541 This will be helpful
08-24-2019 02:42 PM - edited 08-24-2019 03:11 PM
@mellondon wrote:Hi everyone. I finally got my canon ip110 printer working on my phones hotspot. My question is will I have any issues when I’m in the us. It’s working with p/m when I print something. Will it still work when it switches to t-mobile or at&t and I need to print something ? Thanks
cheers
don.
This is highly dependent on properly programmed software and printer firmware, but you should be fine. Printers that have Wi-Fi features only need that the device being printed from and the printer being connected to the same Wi-Fi network. It doesn't care what the source of that internet connection is.
08-24-2019 02:27 PM
cheers
don.
@mellondon Yes it will, as long as you data connection is up and running it should work the same.
