01-28-2026 10:33 AM
I am having trouble accessing my account. I believe I had cancelled the service 2 months back but I am being charged for last 2 months. When I try to login with the username and password, it says invalid. I tried to redrive the email and password saying I forgot them with the phone number, but it I get invalid phone number message. What can I do in this situation? I can't access my account, the service is still active and I am being charged. I want to cancel this service.
Please advise, thank you.
01-28-2026 10:54 AM
if you cannot login , that confirmed your account have closed. Should be an easy ticket to get your money back
01-28-2026 10:50 AM
Thank you. I did.
01-28-2026 10:50 AM
I unsubscribed the service as it was a temporary number. The problem is now I can't login to the account and it says the phone number is invalid. But, I am charged twice even after unsubscribing.
01-28-2026 10:38 AM
did you port out the number or you just disable Autopay?
if you just disable autopay, check your My Account again. Go to Payment > Manage Subscription and check if subscribed is disabled
if it is disabled, or if you ported out, check with PM and arrange refund
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
01-28-2026 10:36 AM
hi @sr61
ask PM support agent to issue refund, you can submit ticket by direct message:
