Hi PM community
Bruan
The name on my public mobile community is wrong. My name is Brian. The name on my account is correct, so it’s only when I’m in the support that it shows incorrectly. And everywhere I looked, it’s all the right name. So how do I change it for the public community support?
thanks 🙂
@hTideGnow wrote:
we used to be able to change Community name, for a short period of time.  Someone abused it  by changing new name every day and PM removed the function.
The above isn't entirely accurate.  Although the feature did work at during that time, the mass Community-base was never supposed to have had the ability to change usernames.
Bruan
Thank u! I appreciate ur response. I guess I’ll just let it be.
hi @Bruan
but Community name does not have to match your own name, like any community, the name in fact should be different from real name for privacy reason
but if you like, you can try asking PM support agent, but I heard they might not help unless there is a legit reason.  Try submit a ticket and ask.
 submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
slusagm
For community name change, you need to ask PM to help with that
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.)  Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
