04-24-2026 04:10 PM
I can't connect with public mobility to release my phone number to bell mobility.
04-24-2026 04:24 PM
I submitted ticket....hope someone replies and issues gets resolved
04-24-2026 04:13 PM
You have submitted your port request with your new provider, Bell? are you just not getting the porting authorization text from Public Mobile?
Make sure your PM account is active and you can still receive incoming calls and text
Then call Bell and ask them to re-trigger the porting request.
Wait another hour or two and you should receive the Porting Authorization Text from shortcode 4799 or 4800
If still not receive the text from PM asking you to approve the porting, please open ticket with PM support using this direct link: https://urlshortner.tiia.ai/Lc9xk8
Make sure that you respond to this text within 90 minutes. If you do not receive this SMS or you do not respond within the 90 minute window, make up to 4 additional attempts to send it. If you are still experiencing any difficulties, reach out to a Customer Support Agent
(Ref: https://www.publicmobile.ca/en/on/get-help/articles/porting-out )
