Help
Clarkymalark
Agent
2 REPLIES 2
Chalupa_Batman
Public Mobile is a self serve service. These forums are the first point of contact for help. What issues are you having? We may be able to help here. If you really need a CS Agent, here's how.
If you are able to log in, please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
If you’re unable to log in to your account, please use this direct link to reach out to a CS Agent.
hi @Clarkymalark
what kind of help do you need?. you can share here and maybe the Community of customers can help
But if you want agent and you can login My Account without trouble, you can submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
