Help
Pri_das5
I can’t receive my 6 digit eversafe ID code. When I select resend code I still receive nothing nor am I able to select to send the code to my email address. Please help
2 REPLIES 2
NDesai
It usually rakes a few mins for the code to come up on Emails. Also make sure to check your junk folder. If you still don't receive the code, contact PM customer support through the chat option.
CSA_PM
Hi there
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
