Help
Lyllibiscope
@CS_Agent
Need help my husband has broke his phone and cant access his email as he always used face recognition 🤦🏻‍♀️ his email is xxx@gmail.com and his phone number is 1-xxx-xxx-xxxx and he can not access either need help
edit: Personal information redacted by will13am.
edit by computergeek541: removed category labels that are unrelated to this situation
8 REPLIES 8
hockeytalk
@will13am
Are you unable to edit posts? The OP has posted personal info it would be helpful if you could use your oracle privileges to do so? Unless I'm wrong?
Thanks!
hockeytalk
@Lyllibiscope
Also you will need to go to your photo library to delete your screenshot. Click on your avatar at the top right corner of your screen and go to your profile. Scroll down to your photo library and delete your screenshot.
ORNGNBLK
@Lyllibiscope  Also, could he not use your phone or a computer to access things like email? Unless Im missing something else.
hockeytalk
@ORNGNBLK
Good one! Hadn't thought of that since the phone is just broken not lost!
hockeytalk
@Lyllibiscope
Does your husband know his voicemail PIN/password? If so he can click on "Didn't get code?" And choose the voice call option. Then call his phone # and press "*" when voicemail answers and enter his voicemail PIN/Password to access his messages to obtain the 6 digit code from Eversafe.
ORNGNBLK
@Lyllibiscope  please delete you personal info for starters. this is a public forum. 🙂  Next - if you can swap physical sim cards between your phones,  he  can receive any pertinent texts to access his account temporarily that way.  Hope this helps.
hockeytalk
@Lyllibiscope
Oh dear! Please edit out your personal info as this is a public forum. Click on the arrow on the right side of your post. Then we can help you with your issue.
will13am
@Lyllibiscope , there is not much anyone can do to assist with accessing email.  This is a personal issue and really doesn't have anything to do with the cellular service.
