07-11-2024 07:39 PM
Hello I recently purchased data, and did not know it was for US roaming. Is there anyway to transfer that for Canada instead. I need data for canada not the US
07-11-2024 07:43 PM
@Katie709
send a private message to CSA through the following link asking them yo swap the add-on https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
07-11-2024 07:43 PM
Yes @Katie709
Reach out to customer support - they can switch it for you.
