Help with number transfer
Steveparamedic
I passed the 90 minutes and did not respond to text message
2 REPLIES 2
JL9
It will be almost instantaneous, so stay on top of it!
@Steveparamedic   No worry, there is a live support number you can call and they can re-trigger the process.  it is still early and they can re-trigger it tonight.  Check your Community inbox , envelope icon.  I will message you the number there
