Help resetting SIM
LmMrP
Hi all,
Activation failure at very end of the process.
PM sim is in “already used” state.  Need & please help to reset the SIM state.
Thanks.
2 REPLIES 2
Yummy
Did you get SIM form a real retailer or PM or from a 'buddy' or some marketplace?
Maybe SIM is really used already?
slusagm
Try reboot and reset network settings
Or ask PM to help (but help desk closed now, they will reply tomorrow)
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
