3 hours ago - last edited 3 hours ago by computergeek541
My subscription has ended and I do not have any outstanding payments with PM. I am unable to get my phone number released from PM for port through my account.
3 hours ago
@Handy1 wrote:@Deb679 You need to have active PM account to port the number out to new provider so you can reply YES to the confirmation text from PM on PM active SIM card . You can try and ask support if the will verbally approve the number transfer . But I suspect you will need to resume service for 30 days for activePM account to port away to new provider
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
Public Mobile will not approve a phone number transfer to another carrier if the Public Mobile service isn't active. Unless the person is going to Telus Mobility or Koodo, there's currently no reason to contact a customer support agent.
3 hours ago
3 hours ago
@Deb679 it is a rule that only numbers from active accounts can be ported across providers. PM is not the only one having this rule. Just reactivate your service with the cheapest plan and then request porting from your new provider
