Hello
12-03-2021 01:44 PM - edited 01-04-2022 04:57 AM
12-06-2021 07:56 AM
@Rhoda74 wrote:I need ur he'll because I lock my SIM number so I can call our
@Rhoda74 - have you got yourself all fixed up?
If not, It is a bit unclear what the issue is...so, here is trying to help:
Find you PUK: https://www.publicmobile.ca/en/on/get-help/articles/where-to-find-your-puk
“SIM network PIN blocked. Enter SIM network PUK." is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times. Samsung and/or your previous carrier can give you this.
"SIM network unlock PIN" is asking for your previous carrier's unlock code - just contact them with your IMEI (dial *#06# to get it) and they'll give it to you. If you enter this incorrectly too many times, you'll get the error message above.
“PIN unlock key (PUK)” is a SIM-specific code used to prevent unauthorised use of a SIM card.
The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.
- If the PIN code is entered incorrectly 3 times, the phone is locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it.
- Once the PUK is recovered and validated, you will be asked to choose a new PIN.
- Only Public Mobile's Customer Support Agents (CSA) can give you this type of code, which the device manufacturer cannot. Public Mobile's Customer Support Agents (CSA) can be contacted at the following address: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
- Caution! If the PUK is entered incorrectly ten times in a row, the SIM card becomes unusable.
12-03-2021 04:59 PM
12-03-2021 04:50 PM
you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
them can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Support Agent by CS_Agent,Click Here link,to get started. Type,, Ticket ,, Click ,, Contact Us ,, Select your issue ,,
Click here to submit a ticket↗↗.
- or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
- please include in your message,
- phone number,
- account 4 digit pin,
- Email address,
- Customer Support Agent by CS_Agent, will Response to your inbox by private message
- During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
- Monday to Sunday: 6 AM to 10 PM EST
- Note: For public mobile No Support by phone call or Email.. only by CS_Agent, private message..
Good Luck..
12-03-2021 04:47 PM - edited 12-03-2021 04:52 PM
