09-06-2024
12:28 PM
09-06-2024
03:34 PM
computergeek541
09-06-2024 12:33 PM
Yes @Schlief , people tested and confirm it works in Hawaii too
Just make sure you connect to T-Mobile or A&?T or Verizon and use 4G/LTE network mode. You might want to manually test all 3 networks to stay with the one that works best if Automatic settings doesn't pick the best one
09-06-2024 12:32 PM
Yes, USA Roaming bundle will work in Hawaii.
Just enable Roaming and connect to AT&T or T-Mobile network and also enable VoLTE (voice over LTE) in your cellular settings:
