01-08-2024 01:29 PM
I am having trouble texting people, but when people text me I received but texting back won't go through. I need help?
01-08-2024 02:42 PM
Make sure Cellular Data is enabled and reset your Cellular network. See if that helps.
01-08-2024 01:31 PM
@Muffin57 Do you have iPhone ? Is data turned on . Check that your iOS is up to date and see if the carrier profile needs to be updated and reboot the phone . If you have physical SIM card can you try the sim in another phone to test ?? .. if still no luck please submit ticket with support
send a private message To CS_Agents
