08-19-2021 08:29 PM - edited 01-06-2022 03:11 AM
Attempting to assist a friend update his credit card info and there’s no clear way to retrieve his account.
08-19-2021 08:35 PM
Explain your issue to Contact Customer Support Agent by CS_Agent ,
they can solve your issue, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent, and Submit a Ticket
Good Luck
08-19-2021 08:34 PM
Does your friend remember the email address for the login for self service account?
Then friend can reset password.
https://selfserve.publicmobile.ca/forgot-password/
(Check your junk folder)
08-19-2021 08:33 PM - edited 08-19-2021 08:34 PM
@RhondaIngs wrote:Attempting to assist a friend update his credit card info and there’s no clear way to retrieve his account.
Hi there @RhondaIngs
Do you know if your friend ever created a Self Serve account? If not, it can be done here: https://selfserve.publicmobile.ca/self-registration/
If one was created, try the Forgot My Password option.
If you had too many failed attempts, it may have locked access. Wait an hour then try again.
If still issues contact CSA to help get back into the Self Serve account.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them:
1 - Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Private Message to Public Mobile Customer Support Agents (CSA)
