HELP!!!
margaretweinder
I NEED HELP ASAP PLEASE MY PHONE CAN'T CALL OUT OR RECIVE ANY CALL I  NEED SOMEONE FROM THE PUBLIC MOBILE SUPPORT TO HELP PLEASE CONTACT ME ASAP
8 REPLIES 8
@margaretweinder
how long you didn't pay for your service? if over 90 day then your account it's be closed and i hope not.
in my post has a link for contact to support team by private message > CS_Agent
dust2dust
Another approach is to dial 1-855-4pu-blic from another phone and enter your phone number and see what it comes up with. And how about the credit card question?
You were given a link earlier to contact the support people
margaretweinder
i can't call or text or do anything and i don't remember my account all i know my phone number and my info to support it but i need someone from the public mobile to contact me i try to open a ticket i couldn't either
Are you able to login to your account? Are you able text? Internet (not on wifi)? Did you possibly deal with a credit card fraud problem recently?
margaretweinder
i did it goes beep beep right the way
Timer
@margaretweinder
Dial *611 Check your account status.
PM contact support team by CS_Agent
Some more details would be helpful @margaretweinder ...like you are a new customer that just activated, or are you a customer that had working services all along, that this just starting happening?
First, does it show ACTIVE in your self serve account?
If Active, try:
  • restart your phone
  • toggle into and out of airplane mode
  • remove the SIM card and try it into another phone to see it if works
  • Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
  • perform a Reset of the device's Network Settings
  • Check for outages in your area:
https://www.telus.com/en/on/outages
https://istheservicedowncanada.com/status/telus
https://downdetector.ca/status/telus/map/
If issues persist, submit a ticket to CSA for assistance.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them found here:
