HELP!
03-26-2024
02:10 PM
03-27-2024
02:45 AM
computergeek541
03-26-2024 02:17 PM - edited 03-26-2024 02:18 PM
Hello @Kemosabe3421
No worries. If you exceed the limit, it just means the system is doing it's job protecting your account. You just need to wait 1 hour and try again. A few things I'd suggest here since you weren't able to get in on your first 3 tries.
Clear your cache, cookies and history on your browser then reboot. Then try again. This time, click on forget password that way this will help you figure things out. Follow those instructions it asks.
As a last resort, you can reach out to a CS Agent via the chatbot at the bottom right corner.
03-26-2024 02:14 PM
Open a Ticket through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Type ‘ticket’ and follow prompts. Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
03-26-2024 02:11 PM
Cannot log in; cannot change password; Exceeded number of tries on first try
03-26-2024 02:11 PM
inappropriate content removed
03-26-2024 02:11 PM
OK? We are all customers like you. How about you explain what's happening and we'll do our best to help you. Make sure you put as much information as you can so we may pinpoint the problem you're experiencing.
