03-14-2020 09:53 PM - edited 01-05-2022 09:56 AM
Hi everybody
Did anybody by any chance try Gome U7 with public (or any telus/bell company)
A friend is considering
The network is
3G WCDMA 850/900/1900/2100 MHz
4G FDD LTE B1/B3/B5/B7/B8
It seems to be $30 less than umidigi a5 pro but have much less bells too
Those that do understand something about the network, could you please suggest how much worse would lte be compared to a5 pro
A5 pro network
3G network WCDMA: B1/B2/B4/B5/B6/B8/B19
4Gnetwork B1/B2/B3/B4/B5/B7/B8/B12/B13/B17/B18/B19/B20/B26/B28A/B28B/B6
I suspect b7 may be a big deal
Can anybody elaborate?
Thanks in advance
03-19-2020 08:49 PM
Thanks everybody for your input I passed the messages and talked them into fishing for A5 pro, especially since good camera app can turn it into a jewel probably.
03-15-2020 09:48 AM
With repurposing of 3G bands for LTE, B2 and B5 are becoming just as important as B4. But why risk coverage holes when there are other viable options? The only negative with the A5 pro is the terrible camera app. This comment is from a non camera person. It's a software issue and not hardware.
03-15-2020 12:18 AM
@totalUser If a phone does not support B4 for LTE/4G then don't buy it.
03-14-2020 10:14 PM - edited 03-15-2020 04:02 AM
It's missing the 4g band 4 frequencies. So, no 4g LTE data.
The A5pro will give both 3g and 4g LTE data. Personally I would spend the extra $30.
Public Mobile 3G & 4G Frequencies.
3G Frequencies 4G Frequencies
| 850 MHz, Band 5 (UMTS/ HSPA). 1900MHz, Band 2 (UMTS/ HSPA). | 1700/ 2100 MHz AWS, Band 4 (LTE/ LTE Advanced). 700 MHz A/B/C/E, Band 12/13/17/29 (LTE/ LTE Advanced). |
