06-22-2019 02:40 PM - edited 01-05-2022 05:31 AM
Hello,
I am going to vancouver tomorrow I have a plan for calling in yukon only can I call Whitehorse from Vancouver in my plan please inform.
Raghu
07-01-2019 01:20 AM
@raghu wrote:Yes I do see the addon of $5
Raghu
Are you sure you're seeing the line that says:
500 min Canada-Wide Long Distance
under
My Data & Add-Ons
on your overview page?
06-30-2019 11:57 PM
Yeah you want to get it working as it will allow you to call anywhere in Canada in the future.
Terry
06-30-2019 09:54 PM
@raghu did you try to contact a mod yet? https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
06-30-2019 09:42 PM
Raghu
06-30-2019 08:59 PM
@raghu can you see the 500 min addon in your addon section?
06-30-2019 08:56 PM
Hello,
I am back in Whitehorse yes I did dial 1 before dialing 867 and number and still it did not work.
Raghu
06-30-2019 03:22 PM
@raghu wrote:Hello,
I bought $5 add on but I could call in vancouver not Whitehorse from Vancouver, it did not work, I do not know what I did wrong.
Anyway thanks for trying to help me
Raghu
The add-on you bought should work when you call anywhere in Canada. It should've worked when you dialed from Vancouver to Whitehorse. Try adding 1 in from of the number and see if it works.
06-30-2019 03:19 PM
Hello,
Raghu
06-22-2019 04:03 PM
@popping its been a long day![]()
06-22-2019 04:01 PM
06-22-2019 03:58 PM
@popping actually I think he wants the 500 minutes add on for his purposes
06-22-2019 03:51 PM - edited 06-22-2019 04:00 PM
@raghu wrote:Thanks for your suggestion, how do I buy the add on?
Raghu
Login to your self-serve account.
Select [Plan and Add-Ons]--> [My Add-ons] --> [$5 500 min Canada-Wide Long Distance]
Please note that buying add-on is a 2 steps process. First to add fund to your account. Then buy the add-on.
06-22-2019 03:42 PM
Raghu
06-22-2019 03:09 PM
@raghu wrote:Hello,
Raghu
I'd be curious to know if you can call a Vancouver # from Whitehorse. Like 1-604 something.
06-22-2019 02:49 PM
@raghu wrote:Hello,
Raghu
If you have only province wide talk, then you can add on 500 Canada wide long distance minutes for only $5 dollars otherwise you can't make a call from Vancouver to Whitehorse because PM is pre-paid service.
06-22-2019 02:44 PM
@raghu wrote:Hello,
Raghu
You will be able to call only in the same province....but you can buy a 5$ add-on for 500 minutes and you will be good. And it will stay in your account until it's all used.
06-22-2019 02:42 PM - edited 06-22-2019 02:55 PM
@raghu if you only have local/provicial calling purchase 500 minute add on for 5 bucks
