10-29-2019 11:34 AM - edited 01-05-2022 07:47 AM
Hi community! When I click the link of a Go to Solution, invariably it opens a page with more than one post — often even two or greater — and I get a bit uncertain about which one of those posts offers the real solution. Do you also face the same predicament?
If yes, I suggest that the Solution Post should also carry a tag — possibly in a green color — identifying it as the solution.
@Alan_K
10-29-2019 11:55 AM
@Alan_K
After clicking on Go To Solution
the selected solution is usually first / on top.
Look for the post with the green check mark.
10-29-2019 11:38 AM
Try using google chrome, I just tried, and it works.
10-29-2019 11:36 AM
@sa7375, maybe it is your browser. I just tried and it works as advertised.
