Getting Not registered on Network
JefforyBeland
Getting error when ever I am trying to call
The SIM is not working, it seems
Unable to activate the SIM as well
2 REPLIES 2
@JefforyBeland - did you recently activate a SIM card, or is this an account that has been active for a while?
Try one or more of the below:
*turn off your phone, leave off for a few minutes, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*perform a reset network settings on your device
*try your SIM card into another compatible phone...this could rule out a device issue/setting.
*Is your phone locked? Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
*Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
Maybe also try manually select the 3G / WCDMA ONLY network in your Mobile Connections area in your settings (temporarily) to see if calls work.
edit...did you go through the SIM Card activation process here:https://publicmobile.ca/en/on/portal/activation
@JefforyBeland   you just joined PM for couple days and sim never works?
do you have another phone to test the simcard?
honest, it could either be phone being blacklisted or sim card provisiong , especially if you are newly activated
Check if your phone is blacklisted here first:  https://www.devicecheck.ca/check-status-device-canada/
if not, then open ticket with Pm support and ask them to confirm if your sim card was provisioned properly
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
