12-18-2022
05:33 PM
12-18-2022
10:15 PM
computergeek541
Can't get ticket because I keep getting error when directed to login into my community account. Want to ensure that I get my "More the Merrier" Data bonus
12-18-2022 05:40 PM
Use the pin option rather than the credentials option.
12-18-2022 05:36 PM
Try texting YES2 to 4911. If still no promos on your account then try the chatbot again but clear your browser cache and go incognito in a new browser window.
12-18-2022 05:35 PM - edited 12-18-2022 05:36 PM
Make sure your community account e-mail is the SAME e-mail you are using for your self-serve account, @dixonkenny
To confirm, click on your avatar and go down to My Settings.
Then try again.
- Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request). Click the result which states Click here to submit a ticket and follow the prompts, or,
- Send a private message to the Customer Support Agent by clicking here You’ll need to be logged into your Community account for the link to work.
12-18-2022 05:35 PM
hi if you didn't receive the text you can try texting YES2 to 4911 and see if it accepts it if not
you need the help of a service rep to add it for you
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or private message them here
