Galaxy S20 FE
ekda1961
We just got an S20 and it doesn't look like it is supported by Public Mobile.  Will it be?
2 REPLIES 2
Staliger
@ekda1961 That list is outdated. Many old and especially new phones are supported by PM. Your phone will work fine as well as it supports the needed frequencies.
Dunkman
@ekda1961
It should work with Public mobile
Here are the specs:
https://www.gsmarena.com/samsung_galaxy_s20_fe_5g-10377.php
3G bandsHSDPA 850 / 900 / 1700(AWS) / 1900 / 2100
 CDMA2000 1xEV-DO
4G bands1, 2, 3, 4, 5, 7, 8, 12, 13, 14, 20, 25, 26, 28, 29, 30, 38, 39, 40, 41, 46, 66, 71 - USA
 1, 2, 3, 4, 5, 7, 8, 12, 13, 17, 20, 26, 28, 32, 38, 40, 41, 66 - International
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).  band 12, band 5, band 2, band 1, band 4
  • HSPA: 850 MHz, 1900 MHz (UMTS).   B2, B5
