10-27-2022 06:31 AM
Number ported from Koodo Mobile (postpaid account), but activation failed. Also, can't login to my account I created during activation. Anyone can help?
10-27-2022 08:04 PM
Thanks! It's now all been fixed for me by CSA... kudos to PM...
10-27-2022 08:03 PM
Thanks... it's now all been fixed for me by CSA... kudos to PM...
10-27-2022 07:45 PM
Did you confirm to the text with the Koodo SIM in your phone that you are porting your old number over to PM?
If you didn’t that is why you can’t login to your account.
The old Koodo SIM will still work if porting was not completed.
10-27-2022 08:00 AM
@HSKhurana number ported but activation failed? What you meant by that?
Your phone is not connecting to the network at all? or it connects, it can make outgoing calls but just cannot receive incoming?
And , any chance you have made a charge back to any Koodo or PM's payment on your credit card?
10-27-2022 07:49 AM
Was there an activation error message? Before anything else, please check if your aervices are working. If the services isn't working and for the login issue, you will need to open a customer support agent. To open a ticket: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
