09-12-2020 01:06 AM - edited 01-05-2022 01:11 PM
If my acct is inactive can I activate a new account using the same friend's referral code as I did the first time?
09-12-2020 11:41 AM
@Mornerichard wrote:You can, but you will not receive a $10 sign up bonus again if you are just doing a reactivation
For reactivation, the referral code isn't needed again.
09-12-2020 11:31 AM
09-12-2020 01:53 AM - edited 09-12-2020 01:54 AM
@martik777 wrote:If my acct is inactive can I activate a new account using the same friend's referral code as I did the first time?
You can activate as many accounts and use the firend's referral code as often as you want, but why not reactivate the inactive account?
09-12-2020 01:34 AM - edited 09-12-2020 01:35 AM
Make sure your friend is still with PM before using the code.
09-12-2020 01:32 AM - edited 09-12-2020 10:32 AM
If your account hasn’t been inactive for more than 90 days you can reactivate it and you wont need a new SIM card. If more than 90 days you will need a new SIM card and will have to effectively start a new account.
AE_Collector
09-12-2020 01:12 AM
Yes, you can. Your friend is no longer getting any credits from your first account anyway.
09-12-2020 01:08 AM
@martik777 Yes you can.
