05-01-2019 06:40 PM - edited 01-05-2022 04:42 AM
I signed on one month plan a week ago, but my phone frequently shows no service , even a couple of times a day, quite often when I wanted to use it, it shows no services, is there anyone knows what is going on?
05-01-2019 07:22 PM
What make and model of phone do you have? Who was your previous service provider? Did you have any problems with loss of service with your previous provider or with this particular phone?
05-01-2019 07:21 PM
I think I am in an area with good reception
05-01-2019 07:20 PM
Thank you all for the response
05-01-2019 07:18 PM
Yes, it does come back itself
05-01-2019 07:01 PM
@buchaneer52 wrote:When this happens, does the service return eventually or do you have to do something to your phone e.g. reboot?
Not saying this will solve your issue perhaps it's your phone that could be the culprit but it's always a good idea to reboot your phone. I personally do it at least once in a 24 hour period
05-01-2019 06:57 PM
05-01-2019 06:50 PM
There were service related issues last week but they have been resolved. Try using another phone if you have one or switch slot if you have a second one.
You could try putting a small piece of tape over the SIM card to improve the connection. If you are still having issues then you may need to contact a moderator https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
05-01-2019 06:50 PM
Hi, are you in an area with poor or weak Telus service reception? Was your old provider on the Telus or Rogers network?
