Fraud
Jonesd456
My accounts been hijacked. I have an active account  but no esim. I need my phone
2 REPLIES 2
Dunkman
@Jonesd456
Has your SiM card been swapped?  Sim card swap?
https://www.publicmobile.ca/en/get-help/articles/sim-swap-fraud
Are you able to access your account?  If you are able to access via the pM app, then purchase another eSIM and the new eSiM will be installed on your phone.
slusagm
On your phone, download PM app and login.
If you cannot receive 2FA code z click Didn't receive code or Resend code, and choose Send email to get the code via email
Then go to Account -> Purchase Sim card and choose eSIM and buy and install
If you cannot get the code still , ask PM to help. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
