Forwarding
JimRockford_PI
Am I able to forward my PM number to my number in India while I am visiting? If so how?
JimRockford_PI
Wow! Thanks. I am sure that should work as I will only be receiving. The last time I used a similar one, Textme, to send outgoing messages from India, they banned me for life. I guess one-way text is accepted. I will try that solution.
hi @JimRockford_PI
you can't.  however, a workaround is to download VoIP app TextNow. Then before your trip, forward it to the VoIP app phone number.  When you are in India, you can use the app on Wifi or local data
slusagm
sorry, you cannot.  Only can foward to a Cnaadian phone number
