Forgot to add referal code during activation
csaniok261
Hello, can someone advise if I can add the referal code 1 day after activation.
I have the code from another user, but missed to add it yesterday duering activation.
Thank you.
csaniok261
Thank you all, it is fixed
Emily14
Thank you all, cs agent was able to help in a very quick time.
csaniok261
Thank you, I have send a message, let's see if it gets accepted.
Will provide update later.
@csaniok261  You need to message support to see if they can apply it for you
private message   To CS_Agents click
will13am
@csaniok261 contact support and they will update the referral for you. Use the envelope icon to get into your private messages.  Submit a private message to @cs_agent
