Forgot my pin
Alikatt80
How do i reset pin
@Alikatt80
use browser from computer,and clear cache and cookies and use one page inPrivate mode,
your email is working in your account then Login Page  and Profile and reset PIN.
you will get verification code by email or SMS
and when you press the 6 digit number and not press anything
just wait a 3 second automatically be login.
so if your email not working and you can't login to your account contact to support team by send a private message  CS_Agent  to change email or reset password.
No need to contact a CSA and wait, wait, wait for their help.
Follow direct supplied above and you'll be good-to-go in no time.
Alikatt80
Contact someone from support how and where ?
@Alikatt80   you can login to My Account and reset your PIN.
Just go to the Profile page, click on PIN and follow the steps:
https://selfserve.publicmobile.ca/account/my-profile/edit/security-information
