Forgot my email address
Omari-Akbar
Hello
my name is Akbar Omari and I forgot my email address so I can’t login to pay my phone bill please can you help me. Thank you
@Omari-Akbar
If the account is currently in suspended status you can also look into obtaining a voucher to make a payment through 611 (as also mentioned by @dust2dust ),  see here: https://www.publicmobile.ca/en/on/get-help/articles?q=vouchers
Locations to obtain some: https://publicmobile.ca/en/on/payment-voucher
If having issues about which email you signed up for (if you did register for a My Account), use the Forgot your password option to reset it, found here: https://myaccount.publicmobile.ca/en/forgot-password
If an email is received (check spam/junk folder) then the email is likely registered to your account.
dust2dust
In the meantime, you can buy vouchers and dial 611 to enter them. Or use real time payments in some stores.
If you registered a credit card and you know your 4 digit account pin then you can also use 611 to make a payment.
@Omari-Akbar you will need to open ticket with PM support and they can look up the email and reset password for you:
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
