Forgot email
Lamia1
I’m trying to help my mom recover her account but she does not remember which email she created her account under. How can I find out which email is associated with her phone number?
2 REPLIES 2
slusagm
You can try Forgot Login name there.  PM will turn send you an email to the correct mailbox, of course, you have to check all the possible mailbox
Or ask PM to help.   Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
Chalupa_Batman
If you’re unable to log in to your account, please use this direct link to reach out to a CS Agent.
