Forgot email address
Harikumar64
Hi
I forgot the email provided for creating my account.
LitlLdy
@Harikumar64 wrote:
Hi
@Harikumar64 , after you find out which email address & password you used for your “My Account” please make notes of all the information on your account for future reference including the pin # that you created when setting up your Public Mobile account & keep it in a safe place. Also, make sure you use the same email address that you use here in your “Community Account “ on your “My Account “ that way when you need help from a Customer Support Agent (CSA) it will get dealt with faster to verify yourself!
“Also, in case you do not know please do not post any private information here due to this is a public / open forum. We are all Customers here that help each other when we are able to but we do not work for Public Mobile!”
BEER
Have you tried the email you registered on this your community account?
@Harikumar64  - since I see your community account is new, did you perhaps activate in store once upon a time? If you did, it is possible you did not register for a My Account.
So if this is the case, you can register for one with a customer support agent by submitting a ticket with customer support (links provided by @softech ), or you can go to Chatbot at bottom of community page to create a ticket too...type "create My Account".
HALIMACS
@Harikumar64
in all honesty, how many possible email addresses could there be that you might have used?
One of the easiest way to determine which one it is is to simply search the words “public mobile” in any of the possible email address accounts search bar, and the one which creates a hit to public mobile is the one you activated with.
(ADDING:  the above might only be useful if you don’t have multiple accounts with public mobile under various email addresses…)
@Harikumar64
First try to use the Reset Password link there on the login page (or direct link: https://myaccount.publicmobile.ca/en/forgot-password) enter any possible email addresses you could have used and see if it works
If you are unable to self reset the password, PM support will be able to help
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
@Harikumar64
Conduct a search in all possible email addresses for the Welcome to PM email.
If all fails, you need to contact a CS_Agent to help you access your account when all credentials are confirmed.
