Forgot Email
Roshni
Hi,
I forgot my email to login to my account. Please guide me for the next steps.
Thank you
@Roshni
First try to use the Reset Password link there on the login page (or direct link: https://myaccount.publicmobile.ca/en/forgot-password) enter any possible email addresses you could have used and see if it works
if not, PM support will be your friend then, please open ticket with them
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
will13am
@Roshni , are you able to sort through potential emails that you might have used to activate the account?  If you keep legacy emails, look for a welcome email that would have been sent out after successful activation.  That would help to identify the email used to for the account.  If this check is not possible, use the chatbot link to initiate a support ticket and a CSA will assist.
