Forget pin number
Yuzhexue101
Is there a way that I can recover or reset my PIN number?
Yuzhexue101
Send private message to the moderator_team and had them reset the PIN number for me.
What was the solution @Yuzhexue101 ?
Yuzhexue101
Done that, solved it.  Thank you.
popping
@NDesai wrote:
@Yuzhexue101  PIN number is usually sent as a text when you activate. So search through your texts and see if you got your PIN from 611. If not, only moderator team can reset it.
@NDesai Great solution without needing moderator.
@Yuzhexue101 PM sent you a text message with your PIN number right after activation.  If you, like me, and do not delete anything from your phone, look for text message sent from 611.  Good luck.
NDesai
popping
You need to send a private message to moderator to get or reset your account PIN.
