Forbidden A1
JOHN68
Forbidden A1  have reset password even though it work, can not log in, redirected to
Forbidden A1
what to do
2 REPLIES 2
Chalupa_Batman
Usually Forbidden A1 is a sign that the site is down for maintenance. There is no scheduled maintenance I see however it doesn't mean the didn't take it offline for a few minutes to fix something. I'd suggest waiting a few hours then go into your browser settings and clear your cache, cookies and history then reboot your browser and try again. If you're still getting this issue, then yes, reach out to a CS Agent via the chat bubble below.
Sansan
Use the link to submit a request.
If it does not allow, use the other link at the bottom to send a private message.
