Forbidden A1
Babitjulka
Hi
cannot log in it shows forbidden A1
Babitjulka
  • Hi
  • you save the day direct message worked and it’s solved
  • my account wasn’t properly ported
  • thanks
Babitjulka
I have tried  it’s not working
will13am
@Babitjulka , the forbidden A1 crops up a lot for me.  I find that doing a refresh always works.  The page will eventually load.
HI @Babitjulka
Your phone service is working ?
To login My Account, wait an hour and use Incognito/Private/Secret mode on your browser to try agian
if you get the same,  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
