For options
11-19-2018 07:31 PM - edited 01-05-2022 06:09 AM
when I pay money for my plan I didn't get the same options like last month, so I was choose this plan 8 GB at 3G speeds for $50, so like when I check my GB in my phone I see 6.2 GB not like befor ,so umforsurently I was check it my phone when I pay the money I sow 6.20 GB ,so let me know please what's going on????
Payment
11-19-2018 08:38 PM
@Enas1, are you referrring to the phone data meter. I believe android gives you the option to use either MB or GB. 1 GB is actually 1024 MB. There may be some rounding.
11-19-2018 08:19 PM
How did you pay?
- If it's plan due date, then you're renewing the plan. It should give you 8GB.
- If not, then you're just adding to the balance. It should show whatever you're left with for the current cycle. The system will take your money from the balance upon plan due date.
I assume 6.2GB is whatever you're left with.
11-19-2018 07:35 PM - edited 11-19-2018 07:39 PM
Hmmm this is not very clear to me...
First, in theory, when you renew your plan you should always have access to the same plan you have - there is nothing else to do than paying.
Then, where in your phone do you check to see 6.2 GB?
You should check in your selfserve account to see how much data you have left.
The data used in selfserve (real) and on your phone (calculated by your phone/the app you installed) is not always the same.
If you just renewed and right away, you haven't used your phone at all and you have only 6.20 GB left on your selfserve account, then you may want to contact the mods, but otherwise it is probably just because your phone used some data.
